What size mufflers fit?
lakersfan1
Post by lakersfan1 »
Does it have to be round, or oval, or oval offset? Or will more than one style fit? I know I have a round now, but not sure if that's what's supposed to be on there, or if it's an aftermarket style?
IanL
Post by IanL »
Stock is round with two round outlet pipes - Page F2-2
Rick Johnson
Post by Rick Johnson »
Most mufflers fit because our stock muffler is straight and there is quite a bit of room, for some you will just need the get an adapter pipe made up to attach to the stock piping. Any straight thru muffler should fit fine.
