tranny conversion
Posted: January 10th, 2005, 5:26 pm
by mx3racer
ok you guys i need to know what parts i need to take my car from auto to stick.... i'm getting ashort shifter; got the clutch pedal assembly; getting the break pedal; got the clutch slave cylinder; waiting on the tranny(already bought it but it aint here yet); so what else do i need? and i bet that it's gonna be a pain in the butt cause taking the parts i got was a pain so i bet the mounting them on my car is gonna be the same....help me out guys...thanx
Posted: January 10th, 2005, 6:37 pm
by flowinprose04
all I can say is...have fun
Posted: January 10th, 2005, 6:46 pm
by flowinprose04
i spoke too soon, i was just looking around and came upon a website that you might want to check out. it shows the parts that some miata owner needed when he converted his MX-5 from auto to manual. check out
http://www.miata.net/garage/auto_2_5_speed.html I hope this helps.
Posted: January 10th, 2005, 9:04 pm
by Josh
the mx is alot harder than a miata.
you will need
MTX trans
clutch kit
pedal assembly (comes with clutch and break)
master cylnder resevoir
MTX motor mounts
and passenger side axel and half shaft.
if you want to do it rite you will need the wiring harness and ECU
it will run just fine with the ATX ECU if done rite
i have a MTX ECU if you need one for cheep.
you need the clutch slave and lines
and a lot of time it took me 2 days. but their is a saying poor man poor tools, im poor. so it takes a while.
Posted: January 10th, 2005, 10:54 pm
by atlantamx3
Here is my list of what I purchased for the swap.
(Note: You will need the starter for the 5-speed as well)
You will need this handy little link when you think you have everything done:
http://www.atlantamx3.com/BPswap/neutralbypass/
We did mine back in September.
Posted: January 11th, 2005, 12:57 pm
by 93SOHC
don't forget you have to change the tps, they are different from auto to manual!
Posted: January 12th, 2005, 1:25 am
by Josh
the TPS is only different on the 92-93. 94-95 DOHC they are the same from auto to manual. they bothe have the same serial numbers and test out identical.
Posted: January 12th, 2005, 4:04 am
by 93SOHC
oops didn't see the year...my bad
can i...
Posted: January 13th, 2005, 8:27 pm
by mx3racer
can i use a protoge lx tranny?
Posted: January 14th, 2005, 1:59 am
by Josh
yep you sure can. you will just need the axels and half shaft. easy as pie
tranny needed
Posted: January 21st, 2005, 11:54 pm
by mx3racer
ok now i have a lil problem. the guy that i'm getting the engine from dont got a fw tranny he only got an awd tranny of an 323 gtx. i need a fwd hydralic tranny thats gonna fit my bpt. the engine is a 94 and to my knowledge so is the tranny. i'll trade for an 94 mx-3 5 speed tranny with $150 for the awd tranny or take $400 for it. local pick up only in florida. if anyone is interested email me at
light_dragon_24@yahoo.com or post here. i will be checking up on this for the next couple of days.
