Any suggestions?
A place for the MX-3 Community in Europe to gather.
Keir Anderson
Any suggestions?
Post by Keir Anderson »
Is there anything i can do to help prevent the rear-end of my car stepping out when it rains. there is quite a weight diff with having the V6 and then pretty much no weight in the rear but i didn't think it would cause this much trouble. the tyres are brand new, also lowered 30mm but still havin problem wit the handling.Has anyone else had this problem or do i need to replace/upgrade anything to try correct it?
White_mx-3_UK
wokkyie
Re: Any suggestions?
Post by wokkyie »
don't know if this will help. but when i got my mx i noticed alot of stepping out on the back. had someone look at it. they found that the rear suspension links where wrecked. got two new ones (from a mazda 626)now the car is much better on the back.
mad for the motors, motors for the mad
MikeUK
Post by MikeUK »
You say your tyres are brand new? They will need to be worn in before they have full grip.
Keir Anderson
You're spot on. I stopped off by my local garage last night they a look and they said both my drop links were badly worn and in need of replacing.
thanks for the help!!
White_mx-3_UK
Return to “European MX-3 Community”
