-Handling Pack (includes 20-24mm adjustable rear swaybar, front swaybar urethane endlinks, caster anti-lift kit, and two sets of camber bolts). Price: $453.64 AUD which is $285.80 USD<p>-Sports Pack (includes 330mm front springs, and 300mm rear springs, and 4 adjustable koni shock inserts). Price: 880.91 AUD which is $554.98 USD<p>-The Works (inclues everything in Handling and Sports Pack's). Price: 1,268.18 AUD which is 798.96 USD.<p>-The Works Adjustable (Includes everything in handling pack, but comes with adjustable coilovers and struts instead of koni inserts and lowering springs). Price: 3,204.55 AUD which is $2018.07 USD.<p>SUSPENSION PARTS
Part # | Description | AUD Price | USD Price<p>120230 | Laser KF-KH Mazda 323 rear left strut | $168.18 | $105.95
120210 | Laser KF-KH Mazda 323 front left strut | $168.18 | $105.95
120220 | Laser KF-KH Mazda 323 front right strut | $168.18 | $105.95
120240 | Laser KF-KH Mazda 323 rear right strut | $168.18 | $105.95
BFR43Z | H/duty swaybar-rr Blade adjust. (20-24mm) | $204.55 | $128.87
SPF903K | SuperPro poly bush kit (front swaybar) | $15.92 | $10.03
KCA412 | Camber adj bolt kit-12mm (2 bolts) | $71.82 | $45.25
KCA324 | Control arm-rear bush caster adj. | $117.27 | $73.88<p>KCA324X | Control arm caster adj. & Anti-Lift | $180.91 | $113.97
KSB560 | Adj. Front strut tower brace | $162.73 | $102.52<p>KSB537 | Adj. Rear Strut tower brace | $162.73 | $102.52
BFF33 | Heavy duty swaybar-fr (24mm) | $145.45 | $91.64
BFR43 | Heavy duty swaybar-rr (22mm) | $145.45 | $91.64
Here is a link to the parts list for this stuff: http://www.whiteline.com.au/docs/fact_sheets/CK_Maz_323GTX.PDF <p>Here is an article from a magazine that installed this suspension kit on a Ford TX3:<p>
<p>
<p>
