ATX GONE?
MX-3_SPAIN
ATX GONE?
Post by MX-3_SPAIN »
Hi all.
This is my first post, but I use to write in www.3si.org.
My problem is that I have a Mx3 1.6 ATX, and the atx works well, until the car reaches the normal temperature. When this happen, the Hold light begins to blink and the atx gets slippy. I changed the atx oil and filter and no improvements.
I think it's time to change-rebuilt the atx, and I would like to know it the atx of a '92-93 Mazda 626 could work with my car.
Thanks in advance for your help.
Alex.
MITSUBISHI 3000GT VR4
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
MX-3_SPAIN
Re: ATX GONE?
Also, I have readen about the oil coolers, and I will place one with a vent when I have my atx reapaired.
Thanks and best regards.
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
guyaverage
Re: ATX GONE?
Post by guyaverage »
Personally I'm not 100% certain, but I am quite sure the 626 tranny will not work.
Before you dive in, pull one of your factory cooler lines off and run the engine for a second or two, and see if you are getting any flow. If not, cure that problem first.
This could be a temp sensor problem. I dont have access to a factory manual anymore, cant really help beyond this.
"The answer is: More power. I dont care what the question is."
-Tim Allen
MX-3_SPAIN
I took the factory cooler lines, and no flow goes in them. I think maybe the oil pump is burned or perhaps the shaft doesn't move the oil pump.
I'll take a look at the oil pump and see what is happening.
Regards.
Alex.
MAZDA MX5 MIATA
MAZDA MX3 1.6 ATX
KAWA ZZR 250
YAMAHA WARRIOR
Return to “Transmissions”
