BLINKING HOLD- I KNOW BUT HELPME ON IT 1600 Series
Posted: June 4th, 2004, 5:00 pm
by madhatt99
Hey guys. Im trying to sort this out and its not going very far. I have a MX-3 1992 1.6. I have a blinking hold light problem and I cant seem to get rid of it. The car will not change gears when I get onto the highway. I thaught it was the VSS but my car doesnt have one. I just changed out the ECT sensor and the other sensor right next to it. both have something to do with the temp. This was per Mazda dealership recomendation. He said that the temp sensors might be responsible for kicking it off.
I have no clue and am getting really fustrated.. Ive been at this since October...
Re: BLINKING HOLD- I KNOW BUT HELPME ON IT 1600 Series
Posted: June 4th, 2004, 6:45 pm
by perhapsadingo8yerbaby
You say the auto trans won't change gears. This probably is causing the hold light to flash. If memory serves, when the trans. control module (TCM) detects a trouble code, the hold light will continue flashing until the trouble is corrected. Can't recall if the hold light flashes in synch with the trouble code ID but it might. Have you pulled any codes yet to ID the problem(s)?
Posted: June 4th, 2004, 9:17 pm
by Nallboy
My 92 RS's hold light used to blink most of the time too... then the tranny died. I replaced it with a rebuilt one and a new torque converter, and now it runs great as my daily driver. I realize that doesn't really help you at all, but I just thought I'd let you know that it can be a real warning.
Posted: June 6th, 2004, 3:41 am
by hondah8er13
whenever the hold light flashes in an mx-3 that means "serious problem with the transmission" this is what mazda told me...whehn was the last time it was serviced? same thing happened to me then i had it serviced runs great....just a thought
Posted: June 15th, 2004, 7:00 pm
by madhatt99
I had it rebuilt before....and it ran fine for about 6 months then it started blinking again... I was told thatit blinks for an error but when we tried pulling the errors it just blinked at regular intervals - no error codes.... It totally driving over the edge....
New thing withit... when I put it in drive the damn thing stalls out... I will look into the TCM see if that might have anything to do with it... I was also told by the Mazda dealer that the thermostat sensors on the motor maybe shot.. i changed out one that was kinda coroded... the other was fine....
Posted: June 16th, 2004, 6:52 am
by guyaverage
If the engine starts and runs ok but stalls when put into gear there is a good possibility that the torque converter is locked up.
Posted: June 16th, 2004, 7:21 am
by madhatt99
hmmmm.... the engine does run fine... we put it on the lift and you can put it in drive and it will turn the wheels but it abruptly stalls when its on the ground... would that still be the torque converter.
Posted: June 16th, 2004, 1:31 pm
by guyaverage
That would be correct.
The millions dollar question is, and one that I dont know the answer to, is it a mechanical/hydraulic fault that this is happening (I doubt it), or is it an electronic fault (which would probably be easier to repair)? I would lean toward it being an electrical/solenoid/computer causing it to be locked up but not having a factory shop manual I cant really go any further than that. You could call around to a few tranny repair shops but I really doubt you'd get an honest answer.
Posted: June 23rd, 2004, 8:51 am
by madhatt99
OK after all this crap, I replaced the transmission with a 93 , removed the harness from another mx3 and the puter... myself - what a nightmare...
we installed the trans and the blinking light stopped, Im not sure what my mechanic did with the harness etc but there is no light maybe he didnt hook up the vss. I dont know. It now changes gears. The stalling problem still exists... I will recommend the solenoid thing to him and see what he says.
I loved my MX-3 now im starting to hate the lil monster.
Posted: August 18th, 2004, 12:16 pm
by piston broke
It would appear that a blinking light gearbox lockout is not an exception. So far it has cost me £700 [sterling] for so called experts to tell me what is not wrong. The codes suggested a solenoid problem; all three solenoids in the gearbox have been replaced to no avail. Next they [the experts] said it was the ECU, so that was changed and guess what? It still doesn't work. They cleaned this, polished that, they poked and prodded and then relieved me of my hard eared cash. This episode has confirmed to my partner [bless her cotton socks] that I am an idiot. Please help me and save my somewhat tenious marital status. Really - Piston Broke.
Posted: August 18th, 2004, 12:18 pm
by piston broke
It would appear that a blinking light gearbox lockout is not an exception. So far it has cost me £700 [sterling] for so called experts to tell me what is not wrong. The codes suggested a solenoid problem; all three solenoids in the gearbox have been replaced to no avail. Next they [the experts] said it was the ECU, so that was changed and guess what? It still doesn't work. They cleaned this, polished that, they poked and prodded and then relieved me of my hard earned cash. This episode has confirmed to my partner [bless her cotton socks] that I am an idiot. Please help me and save my somewhat tenious marital status. Really - Piston Broke.
