So I broke my fuel gauge...
Chasing_Size
Post by Chasing_Size »
My question being.. I snapped off my fuel gauge while being impatient and fitting indiglos on... my question is this.... Is the fuel empty light, and the gauge completely independent? As long as it will tell me when I'm empty.. I dont got a problem with it.... P.s: anyone selling an mx3 cluster? :D
1992 Mazda mx3 gs / 03 / ms8 intake manifold / klze 67mm bored TB/ Custom CAI / 2.5 Custom exhaust / Drift kit front and sides/ CF Invader hood / 17'' MSR gunmetals with chrome lip / Tockico Blues / Suspension technique springs / Leather interrior/ B&M SS / Fully customized interrior (Red and black) / Corvette Red 00 Paint w/ white,blue,gold pearl / Shaved altezzas w/ black trim/ Front rear strut bars / ze ecu ( I think that's all )
Nallboy
Re: So I broke my fuel gauge...
Post by Nallboy »
Man, that sucks. Check around junk yards. I'm sure you can find something. Good luck!
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
marsinner
Post by marsinner »
Dont' worry chasing size, i just fixed mine after having it broken for 17 months from the same thingm, indiglos.
I got tired of resetting my travel meter. Just fill it up and make sure that you reset the travel distance thing on your dash. After about 500 KM (on standard) you should fill up. Thats how i did it.
If you go to the junk yard and get lucky, unscrews the little fuel thing from the cluster so you only have the fuel copper wire and the fuel guage on it. You can stick that into the one you broke and it will work. The reason yours doesnt work, is because you prolly cut into the bottom left on an angle. Which is what i did, but when u do that the guage doesn't have a little plastic clip to stop it from going aroud. And that is why it goes to full. At least it did on mine.
Hope it helps.
marsinner
Post by marsinner »
BTW, forgot to mention , no it will NOT tell you it's EMPTY, never did on mine. And i pushed the car to 560KM on one tank, i filled up before it died.
lennis
Post by lennis »
I broke my f***** fuel meter to when I was changing to white meters :/. Haven´t had time to fix it yet, hard to find mx.3 clusters in Sweden :)
Mx-3 GS. CAI, dtm rear muffler, H&R spring with camber bolts. Painted interior, rebuilded front with gs lip and splitters. Real supra rear wing custom fitted almost done. blue homemade underkit neon, neon inside, glasfiber glovecompartment with the headunit in. XBOX + 7 inch screen .
SpaceWiz
Post by SpaceWiz »
While we're on it, should the fuel gauges from e '94 Mx3 fit into a '96 Mx3? Im guessing yes but i just wanna make sure before i ask the salvageyard to send it here.. (yeah i actually found one in sweden :D )
mdavis
Post by mdavis »
Using the trip tach kinda sucks because you can't be too accurate.. 1/4 talk of gas in our cars is a huge diff in weight/power ratio. I rarely put more than 4 gallons in at once. When I had my k8 is was <3. You can really tell the diff.
GS-R SE
Fixin's
Gro Harlem
Post by Gro Harlem »
umm...the fuel light is completely independent from the fuel gauge itself. I had a busted needle on mine and the light still came on about 1/4 tankish.
DONATE TO MX-3.COM
