MSD SCI-L INSTALL ****HELP NEEDED****
Posted: July 6th, 2004, 4:49 am
by r1cer4l1fe
Hey everyone,
I bought a msd sci box back in the day for my crx with the blaster coil. Just wondering if anyone has sucessfully installed any aftermarket ignition in the 6 cyl. If so just wondering if you ran into any problems. Since the box and coil are just sitting there I want to install, but upon taking a quick peek at the stock system it looks like it might be a bit of a challenge.
Thanks
Re: MSD SCI-L INSTALL ****HELP NEEDED****
Posted: July 6th, 2004, 7:24 am
by wyldside
I have the MSD 6A with Blaster II coil installed on my GS. I'm not sure how well yours would work with our system though. It can be a pretty tricky mod if you are unfamiliar with electronics. Just use the search function of the form in the V6/Technical section and look for MSD. That should point you in the right direction.
