Ford racing coil over kits
TsiMiata
Post by TsiMiata »
I was looking at the ford racing coil over kits. It looks like the M-3000-Z2 kit for the ZX2 is no longer available, I don't see it listed on fords website anyway. Will the M-3000-Z3 kit listed for the focus work?
91 Eagle Talon Tsi AWD *RIP*
93SOHC
Re: Ford racing coil over kits
Post by 93SOHC »
pretty sure the focus kit won't work, but if someone knows otherwise let me know as well, cause I can get some cheap off my g/f's brother!
tatsu
Post by tatsu »
The rear suspension setup on the Focus is significantly different, so, in a word, no.
As I posted previously, apparently Advance Design makes racing coilovers for the Escort, and I presume that they would fit our cars. They are sold through Ground Control for about $1,600 U.S. per set. They have full threaded bodies as well as adjustable and rebuildable dampers. I believe Sport Compact Car used them on one of their rally project cars a couple of years back, and they said they were bulletproof - dead reliable and very durable.
gm_530
Post by gm_530 »
The Ford Racing coil over kit hasn't been available for a bit now, the Focus kit won't work. Ground Control would be your best bet if you want coil overs.
Steeb
Post by Steeb »
there are other companies that make coilovers for other cars like escorts. try searching for coilovers made for escorts. some companies like dms make a few different types of coilovers for escorts. there are other solutions out there.
id recommend advance design coilovers because they are priced far less than other coilovers i have seen that fit our cars. they should perform quite well also for the price
