Is a camber kit necessary?
What is a camber kit? Is it necessary to get one when you drop your suspension?
Jonathan Michaud
93 Red RS
93 Red RS
Re: Is a camber kit necessary?
unless you want to wear out your tires real bad, yes!
For our cars, if you go lower than about 1.5" drop from stock, you will need some sort of additional camber adjustment kit. These usually are in the form of eccentric bolts, which you'll need four of (one per strut). These are usually sold as pairs for front and rear.
Ground Control also makes camber/caster plates for the front only - they will allow more precise adjustment, and also allow you to adjust caster, but they are much more expensive than the camber bolt kits.
I was was planning to install my tokicos and ST springs this weekend (ST=1.3 inch drop). Are they still necessary for such a small drop? If so, how much are they and where can I get them?
Jonathan Michaud
93 Red RS
93 Red RS
Would a simple alignement after the suspension upgrade do the job?
Jonathan Michaud
93 Red RS
93 Red RS
- atlantamx3
Yes-- that will be fine.Originally posted by Brainless:
when i dropped my car 2.5" appro. (yes it was slammed but the ride SuCkEd) i ran through a BRAND new set of tires in 4 months, there's a good comparison (SP?) for you. to be honest i would just get it aligned after you drop it... as long as it isnt more than 1.5" (stated above). i really need to lower it again :p !!
95 Mazda MX-3 DOHC 4cyl.. 17's, Cat Back w/ 4.5in Tip, Custom Int.(CF Bezel,White and Black, 7"AutoMeter Tach, 4 Neons Hit W/ Bass, $375 Kenwood Headunit), $1300 Custom System(Including 2.25Farad Cap. Custom Built Box w/ 2 cut outs for 6x9's, 2 12" Infinity's, 1200w Amp, 4 tweeters. It might not be as fast, but it sure as hell looks and sounds better than a Honda! CF Invert. hood! Primer&Fittin Drift Front and Sides w/ K-Max Rear.
so camber is adjustable on these cars OEM? Sweet! ( Lots of cars have non adjustable camber from the factory, i.e no ecentric bolts)
get it aligned at a mazda dealership too....regardless of the extra cost.
NTB, Sears, Mr. Tire sucks...they never seem to get the alingment right when i pay for it.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
How much should I pay for some decent camber bolts?
Complete kit of four.
nope-mx3
nope-mx3
