Turbo set up for BP warning *PICTURE INTENSIVE*
Posted: November 20th, 2004, 1:26 pm
Well I've mentioned a few times about the turbo set up on the way. Now I can say that it is no longer on the way... it has arrived. Now the only problem is that I still need to put the BP into the car. :p I have a few weeks off of school over the holidays, I'm hoping to finalize everything then. I still have pipes and brackets to build here... I'll have to either just tack it and take it to someone with a better welder or get some gas for my ****ty mig or the pipes are going to look like *** in comparison to the rest.
Anyways, a few quick details.... the manifold is stainless with radiused entry and exits. rebuilt T3/T4 turbo. Decided to stick with the internal wastegate and have a proper custom downpipe off the turbo to remove flow restrictions and still provide excellent boost control (boost controller when need be will be my old HKS EVC V). Everything uses mandrel bends schedule 40. You should be able to see in the pics how excessive the wastegate dump is. The intercooler is made from two cores put together. The beautiful thing here is the amount of work that has been put into the end tanks. Each core is split with a very gradual divider for better flow and efficiency.
The parts took a lot of time to build and I ended up going from around 14B quick spooling and 300hp, to the monster of t3t4 for more fun in the future when I have some money to build the bottom end.
All parts are from Turbine Tech in Quebec... minus the head work I did here.
quick pic on the head
<img src="http://members.shaw.ca/beyondambient/images/mani3.jpg" alt=" - " />
The size of turbo I was originally thinking of going with for this year. Probably closer to the stock BPT turbo.
<img src="http://members.shaw.ca/beyondambient/im ... ompare.jpg" alt=" - " />
Flow problems with the wastegate??? ha ha ha.
<img src="http://members.shaw.ca/beyondambient/im ... tedump.jpg" alt=" - " />
<img src="http://members.shaw.ca/beyondambient/images/ic1.jpg" alt=" - " />
picture of divider in IC core
<img src="http://members.shaw.ca/beyondambient/images/icin.jpg" alt=" - " />
tried to show how much room it will take up in the front... minus this is the partscort in my garage.
<img src="http://members.shaw.ca/beyondambient/im ... escort.jpg" alt=" - " />
<small>[ November 20, 2004, 12:53 PM: Message edited by: What ]</small>
