Re: Higher compression pistons.
Posted: February 28th, 2004, 10:10 pm
From MX-3.com UBB (link is here ):
"In essence, a low compression motor is good to turbocharge, because it is just easier to do so...and not worry about it. But is that what we really want to do as enthusiasts? Do we want to just slap a turbocharger on a car, and call it a day? Absolutely not. With turbocharging, comes the responsibility of tuning and care. If you are just going to turbocharge your car, and call it a day, then frankly, you don't deserve the luxery of boost! As well, might I add...that simply because it is easy to slap a turbocharger on a low compression motor and not worry about it, does not mean that it is right. I can guarantee you, that if you turbocharge a low compression motor, and fail to tune it correctly, you will end up on the side of the road, with blue smoke coming from your exhaust pipe.
Generally, a lower compression motor affords you more margin of error, when tuning. A slightly imperfect a:f ratio probably won't lead to the demise of your motor...unless you drive like a total jerk.
Why should I consider a higher compression motor, while making my decision of what motor will suit my needs?
Different from a low compression motor, a higher compression motor will not give you a large margin of error, when tuning. As stated before, if you expect to slap on a turbocharger, and call it a day, well then stay away from the higher compression motors all together. A higher compression motor demands slightly more TLC than a lower compression motor. But oh, the rewards are plenty.
Bottom line...a higher compression motor, pound for pound, will make more power, than a low compression motor. This works along the same lines as naturally aspirated Honda motors. You never see an NA enthusiasts spouting off about low compression do you? No, one of the keys to NA performance is high compression. So, why should it be any differnt for turbocharged applications? Of course, the routes to high compression are different (NA uses lightweight rods and pistons, that a turbocharged application would simply tear to shreds), but the end goal is the same. "...
Hope it helps!
Hope it helps!
