S-AFC and 3 wire TPS
Found some very interesting info on the limitations of the S-AFC when using the OBD-I ecu from either the '92-93 RS or Pro LX. I have been looking into why the adjustability only seems to allow for cruise and wot speeds, this fills in all the blanks. The testing has been done, now I just need to get a 3 bar MAP sensor (2 bar won't cut it as I already run 15psi...when the car runs
)<P>Here is the link, you will want to scroll down to "spooler"'s post, the info is in the first 2 links.<BR><A HREF="http://www.miataforum.com/ubb/ultimateb ... 1;t=014787" TARGET=_blank>S-AFC with 3 wire TPS/460cc injectors</A>
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
Re: S-AFC and 3 wire TPS
Found a site with the needed info to do the MAP mod, looks very simple. This will basically apply to anyone using the S-AFC on a OBD-I ecu.<BR><A HREF="http://www.2gnt.com/www/corbin/foolafc.html" TARGET=_blank>Fooling the S-AFC</A>
Chris Malden
MX-3 RSR
MX-3 RSR
- cjthor
Would this be the same with the 94 RS? Ummm. I think I have obd2?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
You could run it the same. Check your TPS sensor and see if it is a 3 wire or 4 wire. I believe all OBDII ecus were 4 wire, technically you shouldn't have a problem (although I have heard otherwise). You could just use the MAP sensor so it would rund of the MAP voltage basing fuel adjustments on Boost %.
Chris Malden
MX-3 RSR
MX-3 RSR
