Does 94-95 dash fit on 92-93???
Posted: May 22nd, 2004, 4:26 am
by kmvmx3
I personally do not like the 92-93 dash of the MX3. I would like to swap the 92-93 dash/console with the 94-95. Are they interchangable and has anyone done it before???? Thanks.
K.
Re: Does 94-95 dash fit on 92-93???
Posted: May 22nd, 2004, 10:13 am
by atlantamx3
It is theoretically interchangeable-- but it is WAAAAAY more work than you want to put in. I think the dash frame and everything between the seats and the firewall are completely different. You would need a complete donar car to do it-- and ther are so many screws & clips that you will never remener where they go.
I am not sure if anyone has one it before.
Have you sat in a 94-95 before? I like the 92-93 because it lets you see better and is more simple.
Posted: May 22nd, 2004, 3:02 pm
by quicksliver
With the right amount of money, anything will fit.
Posted: May 22nd, 2004, 6:49 pm
by kmvmx3
So.... I guess no one has done it. Since they share the same interior demensions and cluster is the same, I thought that it would be an easy swap over. If no one has done it, it is either too hard or that everyone likes the 92-93 dash the way it is. If anyone has done it, just let me know. Thanks for the input so far.
K. :p
Posted: May 23rd, 2004, 3:30 am
by LiquidKarma
actualy i think stacey did it in her old mx-3... but she sold it ...
Posted: May 24th, 2004, 9:14 am
by ToyK
I have done it, too.
Tooks a day of work.
Dash frame from the PRE, tooks a bit time to mold
the new one on it.
You need all but not the handbreak-cover, theyre
the same. Also you need to change the connectors
from the dimmer, mirror-switch, Hazard-switch,
normaly the fog-switches and rear-windshild-/
AC-switches also, but the old ones fit in.
I haven`t changed the HVAC-control.
Takes a bit time, but it can be made.
Greets
TK
Posted: May 24th, 2004, 12:46 pm
by MrMX3
so your saying you were able to do it without having to swap the dash frame over? That's all that's been stoping me from doing it, because with a new dash frame, it means having to change your steering rack as well.....
Posted: May 24th, 2004, 4:09 pm
by ToyK
Hope you did not misunderstand me, i kept the old
frame, no change of the steering rack.
Pic:
http://www.mazda-mx-3.com/images/nickpage/201084190472.jpg
See: old Steering wheel, slider HVAC-Modul
Greetz
TK
