Oil grade?
djjarco
Oil grade?
i just changed my oil for the first time at lubex today (i just bought this car a few weeks ago) and they recommended 10W30 oil year round? has anyone else been following that rule? and if not, what are you guys using? also, what tire pressure do you recommend. i drive a 1994.
Kim 95' V6 DK
Re: Oil grade?
This is proberly no help bc. i live in Denmark and the wetter are not the same as in Canada but i use Quaker state 5/50 and that is the best oil i've ever used!
<I>Why get a car whith more than two doors when your not running a daytime kindergarten</I>
Re: Oil grade?
My Chilton's book recommends 10W-30 for temps from -10*F and up. And 5W-30 for temps below 30*F. I use 10W-30 in the winter here in Texas, but in the summer I use straight 30W since my car has such high mileage. As far as tire pressure I recommend going with the specific tire brands recommendation. It should be located on the sides of the tires. It is often between 32 and 35 psi. Hope this helps. Later, Robert.<BR>BTW- Mazda recommends an oil and filter change for non-turbo engines every 7,500 miles (12,000KM), but I change mine every 3,000-4,000 miles just for added assurance.
Re: Oil grade?
I use 10w30 all year round here in san antonio b/c of the heat.using 5-50 isnt that too thick for a mx3
- cjthor
Re: Oil grade?
hey all,<P> I live in cali and run 10-30. If anything I would run 10-40 in canada but you might wanna call you local dealership to see what they use.<P>------------------<BR>Jarid Perry<BR> 94 Blaze Red RS<BR> 14.62@99.4<BR> Now with NOS
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
