Page 1 of 2
Noise from Trunk?
Posted: January 24th, 2003, 5:16 am
by Soulflare
Anyone here has trunk rattling noises?
Re: Noise from Trunk?
Posted: January 24th, 2003, 10:13 am
by Sonicxtacy02
lots of people do... here's some things to check.<p>1. the trunk latch. I wrapped electrical tape around it and it shut up.
2. The spare tire well. Make sure there isnt any loose tools in the well. I Dynomated mine and that noise went away.
3. Tire Jack. Make sure its securely fastened with the bolt it comes with.
4. Hatch cover. I'm not quite sure what to do to secure it when going over bumps.<p>If you've checked all of these things it could quite possibly be the foam bumper reinforcement rattling around between the bumper and frame of the car. That noise isnt really heard from the inside of the car.. its almost a buzzin noise heard from outside with bass hits.<p>Hope that helps.
Posted: January 24th, 2003, 11:31 am
by your2slow
for the hatch cover, i put velcro strips on the sides...Worked perfectly for me.<p>[ January 24, 2003: Message edited by: your2slow ]</p>
Posted: January 26th, 2003, 5:59 pm
by Soulflare
thx guys
Posted: January 26th, 2003, 6:10 pm
by Andrew_Pakula
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Sonicxtacy02:
<hr></blockquote><p>Haha, ALL of the above apply to me. My trunk right now is super creaky and noisy, I've just been too lazy to try and fix it, maybe when the weather is warmer, in the mean time I can put up with it. Just blast your music louder
Posted: January 26th, 2003, 7:53 pm
by anjin1982
"Creaky" thats mt hatch i try those things...as for the velco where do you put them?...
Posted: January 27th, 2003, 3:22 pm
by your2slow
for the velcro, i put mine on the side's. only down side is when i open the hatch i need to un-stick the velcro. but no biggy
Posted: January 27th, 2003, 8:46 pm
by laboiler
Check your strut bushings, they make a very heavy thump, I've also found a piece of junk rattlin around in the speaker well, and a screwdriver down where the seat folds, also the left rear muffler support is so close to the spare tire well that it can hit if not properly supported.
Posted: November 10th, 2006, 6:24 am
by illapino
i removed all of the large plastic black "housings" that surround in the trunk, which includes the displacement of the rear speakers, and i also removed everything from the spare tire well, including its wood "lid", and Still I Have A Noisy Trunk ... I'll post pictures soon. Removing all this stuff did nothing to alleviate the creaks and knocks over rough roads. What could it be? Suspension is all new, and my installer refuses to blame the coilovers he installed, but if it has to do with the suspension, I'm thinking rear swaybar bushings or strut bushings (although struts are new, just not the upper mounts though)
What's All That Racket Back There!?! Stop It!! STOP IT
Posted: November 10th, 2006, 7:22 pm
by Vanished
when you hit a bump and theres some banging, its probably your bushing seeing as you have new suspension.
If it's a clank, its your coilovers. They're known to do that.
If it's a hard click, it's your axels (when turning)
Posted: November 27th, 2006, 8:25 pm
by illapino
everything is out and the sounds bang exactly the same !!!
Posted: November 27th, 2006, 11:46 pm
by Cy
My Trunk is stripped.. clean to metal...
Still does it...
The Suspension is brand new and I know that squeak...
I hate the damn metal/metal rattle(gonna try adjusting the hatch)
Posted: November 28th, 2006, 12:00 am
by illapino
Cy, did u try replacing swaybar bushings?
Posted: November 28th, 2006, 6:14 am
by Cy
Negatron..although I replaced 1 of the swaybar links..
I'll cut some rubber today and replace them while the car's on the lift @ the engine shop
The rattle is upper car though and in the cabin.. Not muffled @ all..
Posted: November 28th, 2006, 7:19 pm
by mrmike420
Maybe need to replace your hatch struts (dampers).... I know mines are worn out and make a lot of noise when I open and close the hatch... I can only imagine it makes noise when I hit every bump too! lol.
