Oil in spark plug well
Mr Mx
Changing my spark plugs today and found oil in one of the rear spark plugs wells. Is this serious?? I think it could be the rocker cover leaking. If so is this a hard job to do??
Re: Oil in spark plug well
i had the same problem with my 4 cyc mx and it was the valve cover gasket.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
I am doing my head gaskets in my GS and i have the same problem as you. Your problem might also be leaky valves or just the valve cover gasket. The Valve cover gasket is not too hard to change. The hard part is going to be getting the IM(GS) off without breaking anything. If you need some help/tips and you do have a GS PM me and ill try and help you out. Good luck with that.
1993 Mazda Mx-3 GS-Sold
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition
MY WORKLOG, check it out
viewtopic.php?f=46&t=79959
Gro Harlem
leaky valves? how could leaking valves, which are interconnected to the combustion chamber cause oil to appear on top of the spark plugs?
The only thing this could be is your valve cover gasket. Replacing the rear one requires removal of your intake manifold which is a pita.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Well maybe i was wrong...I had a mechanic tell me bout the valves and i to this day never really understood it. I was just trying to give my .02 cent. For the record tho i was half right!!
Leaky (worn) valve guides will allow exhaust gas to pressurise the camshaft chamber, which will help push the oil through the leaky gasket. Perhaps that was what the mechanic meant.
perhaps....thx for clearing that up.Originally posted by IanL:
