Horn stopped working. Any ideas?
Posted: January 10th, 2004, 10:46 pm
by jumboplay
Recently my horn stopped working. All fuses and relays checked, I hear it click when I try it, nothing happens. Any common problems with this? Also, where is the horn itself, since the online shop manual seems to have disappeared? :-\ . Any help would be appreciated? Or maybe I'm just low on horn fluid? Hehehe... :roll:
Re: Horn stopped working. Any ideas?
Posted: January 10th, 2004, 11:43 pm
by Taras
If it is clicking then it is your relay. You wiring must be fine. I would say the horn itself is damaged. May be got too much water. It is behind passenger side front turn signal assembly. May be a good time to upgrade to something better.
Posted: January 15th, 2004, 6:57 pm
by DJsMX-3
Measure the voltage at the horn,while having someone depress the honker :)
