MAF install
Posted: June 30th, 2003, 11:23 pm
by g3939
I have had three different shops run a diagnostic on my car and they all told me that my MAF sensor is bad. A new one is $230 but I need to know how to put the sensor in. Is it as simple as take the old on out, put the new one in or do I have to do some type of adjustment/setting(the computer or the sensor itself) please post replys as soon as possible. I've looked through the manual and the forum but found nothing on installation procedures. PLEASE HELP
Re: MAF install
Posted: July 1st, 2003, 12:00 am
by Zoso124
Unless your MX-3 is a '96 and came from Canada your car has a VAF. How did they diagnosis the problem? Just read the codes? What they get "08" Hows the car running? What are the symptoms? You might wanna try troubleshooting the problem before you blow $230 that most likely won't solve the problem.<p>http://www.mazdamaniac.com/shop_man/f2-152.htm
Re: MAF install
Posted: July 1st, 2003, 11:41 am
by g3939
the check engine light comes on as soon as I start the car. it idles very high too, even when in gear(2300rpm in park or neutral 1100rpm in rev or drive). after about ten or fifteen minutes the C.E. light goes out and the car stalls.and its hard to start again, but if im not at a light it will keep running but won't go past 4500rpms, it just sputters. i have to ease back off the gas for the car to change gears(automatic).
Re: MAF install
Posted: July 1st, 2003, 5:20 pm
by Gro Harlem
I thought the 94-95' RS's have MAF's, and the SOHC 1.6's don't.
Re: MAF install
Posted: July 1st, 2003, 11:32 pm
by Len-Dogg
I have a 95 RS and I have a mass airflow sensor. If I unplug it I can't even start the car.
Re: MAF install
Posted: July 1st, 2003, 11:52 pm
by Zoso124
This is the V6 Forum so when I make a statement it usually has nothing to do 4cyl's<p>From what I know all GS "V6" MX-3's have VAF.
Re: MAF install
Posted: November 19th, 2004, 10:51 pm
by g3939
sorry it took me so long to post the solution but it was the thermostat. It wasn't reading properly causing the car not to burn the gas correctly. Mazda replaced the thermostat and now she runs good again.
Re: MAF install
Posted: November 20th, 2004, 2:44 am
by hgallegos915
theres a sensor in the thermostat?? o.0 maybe thats why my car floods out...where is this sensor?
Re: MAF install
Posted: November 20th, 2004, 4:09 am
by IanL
There is no electrical sensor in the thermostat. Just the bimetallic actuator which opens and closes it.
All MX-3 V6 use a VAF, including the '96 and '97 models. You will not find a K8 with a MAF.
