fuel injector cleaner
				Coodoodxx
Hey guys, ive just been using stp fuel injector cleaner in my car, pretty well about the same time i do an oil change.  Im not sure if that stp stuff is doing anything, or if its just all a bunch of bs.  If anyone else has some stuff they use that they know works let me know, i appreciate it alot, thanx again.
							'93 mx-3, 1.8L V6, Red
				Bri94GS
Re: fuel injector cleaner
I use it in my car every once in a while too...probably don't need to do it every oil change though, especially if you run high grade gas. If you run 91 or 93, you're injectors should stay pretty clean...
				Coodoodxx
nope 89 all the way, i was just wondering, if there was already a build up, if stp would actually clean that or if id have to get the injectors cleaned at a shop.
