MSD Distributor Cap for MX-3?
Posted: May 6th, 2003, 3:56 am
I installed an MSD 6AL about a year ago using Jeff's instructions. I've had it working no problems, except for the fact that every few months I need to replace the distributor cap.<p>Those of you who have installed it already know that you have to drill a screw through the stock distributor to create a makeshift spark tower to connect to the blaster coil. It's supposed to be securely fastened using epoxy. Well after excessive heat the epoxy melts and it burns around the area damaging the distributor cap.<p>For honda's, etc, MSD makes an actual cap with an actual spark plug tower. I've been looking all over to see if we can adapt one to our distributor or to see if even Jacob's or another brand makes them but have come up empty.<p>Does anyone here know of any alternatives to the stock distributor cap?<p>Any help/thoughts appreciated!<p>Thanks,<p>Antonio
