Problem to start
beavis_man
Problem to start
Post by beavis_man »
Ok here is the situation :<p>I've put my car in the garage for the winter, last week i started it but the check engine light turn on and the motor want to stall when idling low. Over 1500 rpm everything goes right, but when i dont push on gas pedal he want to stall....<p>what can i do !
THANX
Beavis Man
johnnyb
Re: Problem to start
Post by johnnyb »
beavis_man
Ok ,<p>I got error codes : 3 17 and 24<p>What does it mean ?
THANX
Beavis Man
JJ
Post by JJ »
Go under the FAQ Check Engine Light COdes and it will tell u.....then go from there........ :D
_pEace_
johnnyb
Post by johnnyb »
3: 'G' Crankshaft position sensor
17: LHO2S inversion error
24: RHO2S inversion error<p>Points:
3: Distributor connector, wiring from main relay to distributor, wiring from distributor to ECUcrank angle sensor 1<p>17: fuel pressure, injection fuel leakage, ignition system, air leakage, ECU<p>24: fuel pressure, injection fuel leakage, ignition system, air leakage, ECU<p>Fixes:
3: See Online shop Manual section F2, page F2-77
17 & 24: See Online shop manual section F2, pages F2-86 & F2-87<p>[ March 12, 2003: Message edited by: johnnyb ]</p>
