Power Locks on Ebay
Posted: April 13th, 2003, 2:46 pm
by Muzdog
Hi, would this kit <p>http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2410978497&category=33723<p>be suitable to change my 93 RS to power door locks? I am also thinking of getting<p>http://www.slickcar.com/productdetails.asp?ProductID=1620<p>to give me total keyless entry. Would this setup work together and how easy is it to install. If I had it installed professionally could you give me rough idea of the cost.<p>Cheers, Phil
Re: Power Locks on Ebay
Posted: April 13th, 2003, 3:09 pm
by Mnemonic
well you have to get the power locks before keyless entry, im not sure on that kit its semi vague on what cars it will work with, best solution would be check out a few local yards and find you a gs and just take the power options off it'll probably cost you anywhere from 30-50 bucks but at least you'll know it will work
Posted: April 13th, 2003, 3:14 pm
by Muzdog
What would I have to take off? and how simple is it to reconnect it to my RS?<p>Cheers
Posted: April 13th, 2003, 7:12 pm
by Sonicxtacy02
you dont HAVE to have power door locks to do keyless entry. One actuator in each door will connect to the lock rod, then be controlled by the remote.
