Anyone interested in doing an Auto to 5 speed swap?
Posted: September 28th, 2002, 5:59 pm
I have every part that would be needed for the swap but I got a bad ticket recently and I need $$ for a lawyer and fines. Everything looks to be in good condition. I have:<P>Tranny<BR>Clutch<BR>Flywheel<BR>Clutch pedal assembly <BR>Brake pedal assembly <BR>Shifter Linkage and rod <BR>Master Cylinder<BR>Brake Fluid Resivoir<BR>All mounts<BR>All tubes and bolts are in baggies labelled<BR>Both CV joints<BR>5 speed ECU<P><BR>The only thing that might need to be replaced is the axle seal. Should be about 50 cents at Lowes or something.<P>Let me know if anyone is interested. I'm in North Carolina.<P>quaz187@yahoo.com<p>[ September 28, 2002: Message edited by: Q187 ]
