cable for tb
cable for tb
does anybody now how to change the cable that runs from the tb to the pedal.i'm still having a problem when it is hot out and it tends to run high revs,then when you tap the gas pedal lightly it goes down. [img]shrug.gif"%20border="0[/img]
fuzzy red mx-3
pelado
Re: cable for tb
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by fuzzy:<BR><STRONG>does anybody now how to change the cable that runs from the tb to the pedal.i'm still having a problem when it is hot out and it tends to run high revs,then when you tap the gas pedal lightly it goes down. [img]shrug.gif"%20border="0[/img]</STRONG><HR></BLOCKQUOTE><P>Take a look at your TB before you change the cable. It could be that your TB is gunked up.
