Home made intake
Posted: April 28th, 2002, 6:42 pm
by Droopy
Ok I have seen all the talking about the home made intake's but my only ? is I work in a Machine Shop and can get and bend my own tube but do i just by a cone filter and hook it to my tube and just put in the little vacume line on itand pull my whole air box out?? Please give some feedback.....
Re: Home made intake
Posted: April 29th, 2002, 11:50 am
by Quazi5
I'm not the master of intakes and such, in fact it took me three tries to understand what you said but here's my 2 cents.<BR> 1) Why would you hook up a vac line to your intake? Treat me like an idiot if I'm wrong about this. 2) To put in a tube that (I have to assume) will be your cold air induction, you have to take the airbox out. I just recently read that David did his own "Home Depot" intake. Check it out in the new FAQ Forum.
Posted: April 29th, 2002, 6:19 pm
by Droopy
yea i did thanks but the vacume line or whatever it is plugs into the air box now
Posted: April 29th, 2002, 6:29 pm
by 5spd_GS
you can just leave the one vacuumme hose hanging there really... it is attached to the stock air box, but you can unplug it and just leave it there... just make sure you keep the MAF attatched (the plug-looking thing) or else your check engine light will come on, your car will rev all crazy like and pooper out.
Posted: April 29th, 2002, 8:09 pm
by pelado
I believe the vacuum hose is connected to your EGR solenoids. If you expect these to still be functioning many miles from now, then I would give them filtered air.
Posted: April 29th, 2002, 9:01 pm
by Guest
Posted: April 30th, 2002, 2:11 am
by mattster
Hang on... don't forget that you need to keep the VAF (Vane airflow sensor). Without that your car wont run well. In case you don't know it is the piece right b4 the airbox. Check out my custom intake<P><BR><A HREF="
http://www.geocities.com/mattster03/index.html" TARGET=_blank>Custom Intake</A>
Posted: May 3rd, 2002, 2:08 am
by marshmallow15
here ya go guys. there's a pic of my homemade ram-air intake in there. enjoy.
Posted: May 3rd, 2002, 2:09 am
by marshmallow15
