Codes 5, 23, 41
acreves
Codes 5, 23, 41
Post by acreves »
Like the guy with the KLZE in Sacremento I've been having a terrible time trying to get my KLZE to idle. I set it today using the directions of Probetalk, but while on my way to school my motor just shut down. The check engine light came on so I pulled the codes when I got home. The first code I got was the knock sensor, followed by the right hand O2 inactivation, and Viris #1 solenoid. Could a bad O2 cause these other codes? My car has been shutting down when I put it in neutral and step on the brake. It has also been jumping around a little under light acceleration. Any ideas?
