Engine switch...I want a 2-5 liter. 3 questions
Posted: January 7th, 2002, 2:08 pm
by appe
I have 3 questions:<P>1) I have -92 V6. Engine ticks. Blue smoke comes from exhaust. Sometimes the car give it all and then it is fast. But that is seldom. IBut it goes steady and fine but it seems like it does not use all horsepowers, only the few times it suddenly goes well.<P>What can I do about it? Can a mechanic tell what is wrong actually. One said the lifters had to be switched. Ok that maybe solves the knocking noise but what about the smoke. I have to fill oil quite often.<P>2) I would like to have more horsepowers. That is why I am thinking about getting a 2,5 liters V6. Is it much more difficult to change to that one than replacing mine (if it not fixed easily) with another 1.8? <P>3)If I want to change to a 2.5 liter, I assume I use 626 engine. What yearmodel shall I look for?
Re: Engine switch...I want a 2-5 liter. 3 questions
Posted: January 8th, 2002, 3:52 pm
by Mradio
look for 95 and on, <BR>iam doing a 2.5 upgrade right now, and it's not that hard, you just need tons of tools, which i didn't have and had to borrow. plus u should pick a good time, cause right now it's freezing, and it's no fun to work outside.
Posted: January 8th, 2002, 9:26 pm
by 93mxrgs
lol aint it a b---- when its cold, vlad LOL i had a nice heated garage, damn it was HOT in there had to take my shirt off LOL LOL LOL, :) :), just make sure u mark ur vacuum hoses those things are a pain in the a--
Posted: January 9th, 2002, 10:52 am
by Mradio
well the problem is, i bought the car with 2.5 in it, but nothing was hooked up, so i have to figure it out on my own, plus there is tons of wiring harness, which is missing <BR>i borrowed my friends garage right now, brought over a heater and a 500watt light, and they keep blowing out the fuses, it sucks, but better than working outside :)
Posted: January 9th, 2002, 1:39 pm
by Bri94GS
if you have blue smoke and need to keep adding oil, i'm assuming your engine is burning oil....try to find the leak<P>As for the ticking noise, try a 5w30 or 0w30 oil...synthetic if possible. Mine stopped when I added a bottle of Rislone Stop-Tick to an oil change. It lubricates everything so that valves and lifters are quieter. Cost me about $1.49 USD.
Posted: January 13th, 2002, 1:49 am
by Quazi5
I'll tell you now that blue smoke is a definate sign of oil leaking into your cylinders. The "having to add oil alot" just adds to the fact. Burning oil in the cylinders is caused by a number of things. I can't name them all but here's a couple. 1) Your piston rings are going bad if they haven't already done so. & 2) You have a leak at one of your gaskets, which (if you don't know much about engines) means that there is alot of oil leaking which can be very bad if you have blue/white smoke in your in your exaust. Either way it need to taken to have work done on it.<BR>Hope I could help and good luck.
Posted: January 13th, 2002, 4:41 am
by Tom
You might try a synthetic oil like Amsoil 0W-30W. It slows down the oil burning process dramatically if you plan on keeping your car a little longer and squeezing a few year outta it.<p>[ January 13, 2002: Message edited by: 92MX3SixCylinder ]
