squeeking sound from front wheel
For about the last week, I've been hearing a squeeking sound from the left-front wheel. It goes louder when I turn and it comes and goes. It dissapears in the highway and is louder when driving slow.
hi
Sonicxtacy02
Re: squeeking sound from front wheel
if its not a link in the suspension, check to see if its your front end making the squeaking noise (meaning the lip, front spoiler, etc). I had that problem, sprayed with wd-40. Make sure to wipe the excess off!
Shaun Newman
SmokyMcGee
I have the same problem. I was told by my mechanic that its not my brakes. But im so damn sure it is. Does the sound go away when you tap the brake?
No, the sound is almost always there except when I turn. I looked through the rim and saw a thin metal plate behind the disc. I used a pen to push it back until my pen broke. The sound went away for a couple of days and now its back again. It liiks like a shield or something. I think its bent. I'll take the wheel off and take a look again. The sound from old brake pads is different, its more like a screeching sound.
hi
SmokyMcGee
i did that same plate trick.. it went away for a while. then came back... Its a wierd problem. Someone told me it may be a wheel bearing.. i dont see how..i dont know much about those things. But i had to buy them for my honda accord once and it was alot of money. Someone please help with this problem.
I finally found the problem; it is the metal plate thing. I reached around the back of the wheel and felt it all the way around until I found a bent pointy part that was rubbing against the disc. I pulled it back for now and the sound is titally gone. I'm still gonna take the wheel off and take a look. I dont know how it became like that. But the sound is gone, at least for now.
hi
I think that bent metal thing is to warn you that you have worn out brake pads...I hope that that wasn't the case... or you'll see sparks while braking... : )
No, the brake pad itself has a needle which makes a non-stop screeching sound when the pad is worn out. I would not be able to reach around and touch that. This is just a shield. I opened it and checked. It is really thin and it was a little bent. It may have happened in a sharp turn.<BR>thanks though
hi
