Problem with1.8 V6,,, someone help!
Posted: November 20th, 2001, 8:24 pm
by dj_nate
I have a really nasty knock/ping type noise comin from my engine. i was told it was 1 of 3 things, a connecting rod, a push rod, or lifters. if anyone could help, or give me some input on what i shoulde do, thanks alot, if i cant fix it, its for sale for 2000 but please help anyone. thanks ya'll...<P>nate <BR>92 GS<P>alright you all said u need more info...well it did have a noise before all this, it sounded like my exhaust was bad upfront kinda, it was a wierd noise..the noise is comin from the top and center so hopefully thats enough info thanks to all who helped.<BR>and whoever asked me where i was from in pa, i'm from Oil City<P>nstevenson@usachoice.net<P>[ November 26, 2001: Message edited by: dj_nate ]<p>[ November 26, 2001: Message edited by: dj_nate ]
Re: Problem with1.8 V6,,, someone help!
Posted: November 21st, 2001, 12:35 am
by codyhoover
need a little more to go off of. were is it comeing from? bottom, top, back corner, exc....... has it always mad ethe noise or did something happen at the time the noise started? k8 doesnt have lifters or push rods so it cant be that(who told you that?!?!) tell me more!
Posted: November 22nd, 2001, 1:53 am
by Buff1110
theres this spring that goes in the area of your timing belt. its only like $5. iv heard that wears down and u just replace it. there is no loss of power...just that annoying tapping.<BR>Dan
Posted: November 24th, 2001, 4:27 pm
by Zoso124
Spring?? :eek: You gotta be kiddin me, be more specific.<P>Let us know where the sound is coming from, got to be more clear buddy. Where in PA are ya?
Posted: November 27th, 2001, 5:07 pm
by jfbourgault
cam friction gear maybe! <BR>It makes a tapping sound also!
Posted: November 27th, 2001, 5:58 pm
by eunosads
HLA's [img]shrug.gif"%20border="0[/img]
Posted: November 27th, 2001, 6:16 pm
by A.S.
Hey man, I have the same thing. I think this may be your problem. Check it out. <A HREF="http://www.mx-3.com/tsb/b007-95.gif" TARGET=_blank>http://www.mx-3.com/tsb/b007-95.gif</A>
Posted: November 27th, 2001, 6:33 pm
by A.S.
I just called Mazda and they told me its most likely the "Friction Gear Spring"which needs replacing. They sell them for $15 (can) and stock them at the dealership only. You probably wont be able to find the spring at Lordco or any other parts store. If thats your problem, this should do it.<BR>Good luck bro.
