recently i intstalled a new cd player, but while doing so i mixed to wires, i ran the ground throu the lumination wire, my fuse blow right then, thou i didnt realize that was why i did, so i put a new fuse back in, it didnt blow, but then about 30 seconds later smoke come out from behind the dash..... i turned the car off right then, so as of right now everything in my car is working fine, the cd player is hooked up correctly now, but my dash lumination and my tail driving lights are out. so my question is does anyone have a wiring diagram for the mx-3 so i know how hard it mite be to get to this wire, and fix the problem? thanks for the help
pete
car wiring?
ptrouge4
car wiring?
"would you wear a shoe if you had no feet??"..."no"...."then why are you wearing a bra?"
