Re: Amp problem
Posted: August 4th, 2003, 9:08 pm
by 2fazed
So you think the Rampage deck rca output isn't working. Couple ways of checking. If your amp comes on, get a cd diskman and get an adapter fromit to rca's, that's one way of testing your rca's. Or, you can hook-up your amp through high input speaker wires.
Re: Amp problem
Posted: August 5th, 2003, 1:09 am
by 2fazed
Yeah, you can connect your remote wire to any ignition on/off power wire. All you need is a wire tester.
Re: Amp problem
Posted: August 5th, 2003, 7:34 am
by lakersfan1
If you think it's just the remote turn on wire, you can take a small piece of wire and short it from the 12V+ terminal of the amp to the remote turn on of the amp. That will supply a 12V+ to the amp turn on, which is what it needs to activate. That'll at least tell you if it's the remote turn on.<p>But if the amp's light is going on, that uaully indicates that the amp is already being turned on.
Re: Amp problem
Posted: August 5th, 2003, 8:35 am
by Spydie
look in the fuse box by the hood release. there is a fuse marked "radio". you can tap that for your remote wire
Re: Amp problem
Posted: August 6th, 2003, 11:29 am
by 2fazed
So your saying that the amp is staying on regardless of your remote. If that's the case, I believe you have a bad ground. Check that, and maybe it will solve your problem.
