What color is the "constant power" wire?
Posted: December 4th, 2002, 1:58 am
by Moe_maX
topic basically says it all... (on the MX-3)the one from the deck is yellow :o :mad:<p>[ December 04, 2002: Message edited by: Moe_maX ]
Re: What color is the "constant power" wire?
Posted: December 4th, 2002, 10:04 am
by Sonicxtacy02
if you have the wiring harness you just match the colors.
Posted: December 4th, 2002, 10:51 am
by Maddbuck
search through this section and you'll find a good post or two on the wire colours.<BR>blue/red I think it is
Posted: December 4th, 2002, 11:21 am
by 2fazed
Just use a test light.
Posted: December 4th, 2002, 1:30 pm
by Custommx3
be careful using a test light. Poking the wrong wire can set off your airbag. (not on your stereo of course, but wires under your dash in general. I know this may not relate to the question, but its benificial.
Posted: December 4th, 2002, 3:40 pm
by Moe_maX
thanx all but.... i don't have a test light or a wiring harness for that matter... if anyone could possibly post a link of the diagram of "what wires what" that would be great... thanx again for the responces
Posted: December 4th, 2002, 8:45 pm
by airjordon_09
the best thing i would suggest is go to any car stereo place and buy a wiring harness, this would be good because its easier and less chance of messing up and crossing the wrong wires and also because you will be able to still use it if you change decks, this is honestly the best thing to buy, <P> and i just saw that your from hamilton, go over to HI-FI PLUS, and talk to mike, awesome guy to deal with, email me before you go over if you do,<P> peace<P> peace<p>[ December 04, 2002: Message edited by: airjordon_09 ]
Posted: December 4th, 2002, 9:44 pm
by Maddbuck
here you go<BR>Here's what I get from the online manual wiring diagram pg Z-102<BR>Blue/red - battery<BR>Blue/black - Ignition<BR>Black - ground<BR>Red - deck lighting (avoid not needed)<BR>Red/black - deck lighting (avoid not needed)<BR>blue/orange - front left -<BR>Violet - front left +<BR>white - front right -<BR>Blue/white - front right +<BR>Pink - rear left -<BR>grey/black - rear left +<BR>light green/red - rear right -<BR>light green/black - rear right +<P>the red and red/black wire are part of the interior lighting dimmer circuit for the instrumentation lights. for an aftermarket radio they are not needed unless the unit has provision for this but most don't.
Posted: December 5th, 2002, 12:32 pm
by Moe_maX
thanx Maddbuck... that was very helpful
