really cool idea for sub
Posted: April 6th, 2002, 11:41 pm
by Stevech_2001
Hey I saw a mx3 with a sub in the back that was flush with the floor. He took out his spare tire and but a sub there in it's place. I was just wondering if anyone has done, what material you used to do it, how does it sound, what kind of sub? Any ideas would be greatly appreciated. Thanks<BR>This is the link to the pics<BR>members.tripod.com/mx3gsr/Interior.html
Re: really cool idea for sub
Posted: April 8th, 2002, 4:28 am
by monty73741
try google....<BR>there are a few sits that show you how.<P>i was gonna do it but i want my spare tire<P><BR>jason
Posted: April 8th, 2002, 6:39 pm
by j_villines
My brother didi this with his car. He used aluminum foil on the bottom of the trunk and then lined the foil with fiberglass strips and when it dried he did it two more times. He then pulled it out and took the foil off and measured the dimensions of the trunk. He made a support out of wood for the top part of the enclosure and lined it up to sit on the part where the back cover of the trunk sat in. He cut the holes and took some fiberglass and cut the wholes mounted it all together wired and what not then sat it in there. He had three JL Audio Subs with three cheap jensen amps it hit around 152db. Pretty sweet set up!!!
Posted: April 8th, 2002, 8:17 pm
by NickisGod_com
<<i was gonna do it but i want my spare tire>><P>Come on...priorities!
Posted: April 9th, 2002, 2:36 pm
by monty73741
[<BR>Come on...priorities![/QB][/QUOTE]<P>prioriteis!!!!!!<BR>i dont want to look like a sucker with a flat tire.<P>jason
Posted: April 9th, 2002, 5:13 pm
by loudsubz
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jvillan:<BR><STRONG>My brother didi this with his car. He used aluminum foil on the bottom of the trunk and then lined the foil with fiberglass strips and when it dried he did it two more times. He then pulled it out and took the foil off and measured the dimensions of the trunk. He made a support out of wood for the top part of the enclosure and lined it up to sit on the part where the back cover of the trunk sat in. He cut the holes and took some fiberglass and cut the wholes mounted it all together wired and what not then sat it in there. He had three JL Audio Subs with three cheap jensen amps it hit around 152db. Pretty sweet set up!!!</STRONG><HR></BLOCKQUOTE><P>what size and model subs and amps. 152 is pretty hard to believe.
Posted: April 9th, 2002, 5:59 pm
by Sonicxtacy02
he had 152dbs of static..lol. Not with a jensen kid.<P>you should have told your brother to just leave the aluminum foil in the trunk, when it got hot he could open the hatch and cook hotdogs. Then he could buy a chilpac amp to power and freeze a small frig. that my friend is customizing! :D
Posted: April 10th, 2002, 4:02 am
by aidan
that is a good idea to flush mount subs in the wheel well. I have 3 alpine type R DVC's in my hatch powered by the alpine mrvf1507, and it isn't unreal to hit 152db because I hit 150.4db with mine. the best way is to use fibre glass and it makes a nice solid box that has a great sound. I am seeling my car so if anybody wants to buy it give me a gingle-- wanghunglow6@hotmail.com<BR>later.
Posted: April 10th, 2002, 10:50 am
by Sonicxtacy02
hitting 152 isnt unreal. Hitting 152 with jensen amps is.<p>[ April 10, 2002: Message edited by: Sonicxtacy02 ]
