best way to remove wheels/rims
Posted: December 17th, 2002, 7:49 pm
by marshmallow15
i want to rotate my tires and wanted to know what the best method is to removing the wheels/rims. i tried to yesterday but the lugs were practically welded on and won't come off..even after spraying some wd-40.
Re: best way to remove wheels/rims
Posted: December 17th, 2002, 9:13 pm
by sikblue
i have an idea
put the lug wrench on..get a big hammer..hammer downwards and shud pop off... u cant use wd-40 because you wont be able to get it in the threads..if that dont work stop by a shop and have them pop them off real quick or if u kno some1 with an air-impact
Posted: December 19th, 2002, 12:23 am
by Becker
GET MORE LEVERAGE....I just get a big piece of pipe that will fit over my ratchet (like a 2" 4' lead pipe) and it will for sure start to move.
Good Luck
Posted: December 19th, 2002, 12:43 am
by Ryencool
yes the longer the rod the more force, I used a old shower curtain rod, just poped it on grabbed it like two feet up, pushed, and there they went
Posted: December 19th, 2002, 12:55 am
by marshmallow15
oh to give it more torque? i'll try that thanks.
Posted: March 4th, 2003, 6:33 pm
by ryanlindenberg
loosen the lugs when the car is still on the ground<p>jack up car<p>remove lugs<p>rotate tires<p>tighten lugs<p>drop car<p>retighten lugs
Posted: March 6th, 2003, 2:38 am
by cjthor
Fire up the air compressor and hit them with the impact gun.
Posted: March 6th, 2003, 3:15 am
by marshmallow15
yea i found the torque way to be the best route.<p>lol my air compressor and impact gun sucks... didn't take off the lugs.
Posted: March 9th, 2003, 2:12 pm
by NateDog
if all else fails....<p>use the "sawzall"
<p>j/k<p>ummm... have u tryed a breaker bar w/ an extended handle?
Posted: March 9th, 2003, 7:13 pm
by marshmallow15
yep the torque method was best for me. i used a regular tire iron with an extended handle thing that i slipped on and it worked great. thanks everyone!
Posted: March 11th, 2003, 2:43 pm
by miztahfoolish
Put some elbow grease on it. Or use your teeth to take the bolts out.
Posted: March 11th, 2003, 3:07 pm
by Custommx3
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by miztahfoolish:
Put some elbow grease on it. Or use your teeth to take the bolts out.<hr></blockquote><p>Do you post anything useful?
Posted: March 11th, 2003, 3:13 pm
by Zoso124
I know I do Barry,<p>Hey five letters for Marshy<p>T-O-R-C-H<p> :p
Posted: August 12th, 2003, 2:23 am
by mx34u2nve
just make sure you use a torque wrench when you put the wheels back on so your rotors dont warp
Posted: August 12th, 2003, 1:39 pm
by Len-Dogg
I would not recommend pounding on the tire iron with a hammer as was stated previously. The easiest solution is the one that was said several times. Add a length of pipe onto the tire iron, and it will come off. Simple physics.
