Page 1 of 2
another MAF thing
Posted: August 4th, 2004, 4:57 pm
by m92_MX3
ok mine died, and it cost $569 to get one from a dealer, andi know you can take one off an 87 88 rx-7 non turbo but the only ones i can find are turbo, i need to know it anyone has one stock even, or if anyone knows someone who does, or can tell me if there is anyother car with one that would work out there PLEASE car dont work without one thanks
Re: another MAF thing
Posted: August 4th, 2004, 5:42 pm
by Typhoonk
92 V6 or the 4cycl?
but anyway just check out the following link
http://www.car-parts.com
use it and locate a wreckers near you!!! how exciting!!!!!!
good luck :2thumbsup:
Posted: August 4th, 2004, 7:32 pm
by m92_MX3
its the 1.6L sohc
Posted: August 4th, 2004, 7:41 pm
by m92_MX3
thanks that kicks ***
Posted: August 4th, 2004, 10:33 pm
by Domnknpimp
are you guys really sure that the rx-7 turbo meter doesn't fit? I work an auto parts store, and even though they have different part numbers, it IS the same flap style meter. Maybe our sistem is wrong (happens a lot), or maybe the plugs are different? I would check them out side by side, but they're both special order. Thanks
Posted: August 4th, 2004, 11:19 pm
by papa roached
they could be calibrated different
Posted: August 4th, 2004, 11:36 pm
by Domnknpimp
I just emailed some guy selling one on ebay to see if he could send me the specs on it. I personally thing I COULD work if you change the spring rate on the inside of the meter. Chances are you will have to do that either way with the non turbo version anyways ( i kno i hade to make the spring softer so it wouldn't run lean at idle).
Posted: August 5th, 2004, 2:02 am
by MX3-Freak
I was under the impression that the rx-7 used a MAF, not a VAF?? :confused2:
Posted: August 5th, 2004, 2:46 am
by Domnknpimp
The second generation RX-7 (Turbo and Non-Turbo) uses a VAF similar to the one on the 92 and 93 Mx-3 and Miatas.
If you want, look for yourself
2nd Gen Rx-7 (Turbo) Air flow meter
Posted: August 5th, 2004, 2:55 am
by papa roached
that is a MAF, whats used on the later 4 cyls and the V6s is a VAF
Posted: August 5th, 2004, 3:13 am
by Domnknpimp
differences between MAF and VAF
I think if everyone would look through this link, there would be a LOT less confussion about this topic.
Posted: August 5th, 2004, 10:29 am
by MX3-Freak
Ok, (I knew the difference between m/vaf, I just wasnt sure which the RX-7 had...).
Now this I'm sure is partially wrong. The all the GS do use a VAF, agreed. However, the B6-ZE (DOHC 94+) used a MAF. It was the B6-DE (92-93 SOHC) that used the vaf.
MY next question is this... If the Rx-7 used a VAF, wouldnt it have to be much larger to yeild benefits to the B6-ZE MAF? Just by using a trap door instead of a heated wire, the air should become greatly resticted. Just a guess, and it could be wrong (so please tell me if I am).
Posted: August 5th, 2004, 10:53 am
by hotsiit
I believe the
92-93 sohc 4cyl used trapdoor style MAF's
94+ dohc 4cyl used hotwire style MAF's
92+ V6 used VAF's
The 2nd gen Rx-7 MAF's look exactly like the sohc 4cyl mx's MAF (both trapdoor style) it is just bigger. I have an rx maf I just havent gotten around to installing it yet.
Posted: August 5th, 2004, 12:02 pm
by Custommx3
the 92-93 used an MAF.
Posted: August 5th, 2004, 12:15 pm
by atlantamx3
For the love of God... not this debate again...
:roll:
