ground wiring kit
Posted: March 21st, 2004, 2:38 pm
by mxprecidia
i made new grounds for my car with 6 gauge wire. can someone tell me where the grounds for the tranny and throttle body are located? i cannot find them.
Re: ground wiring kit
Posted: March 21st, 2004, 2:39 pm
by mxprecidia
i forgot to say i have a 95 1.6 mx3 automatic
Posted: March 21st, 2004, 4:56 pm
by hondah8er13
just loosen any bolt on the tranny that will not leak fluid and get a good connection there, I mean there is no specific place... also same on the throttle body... :throwup:
Posted: March 22nd, 2004, 12:35 am
by mxprecidia
isnt there a positive and negative comin off the tranny and the throttle body? i want to ground those negatives to the fender
Posted: March 22nd, 2004, 2:34 am
by hondah8er13
Dude, i don't know about all that but why don't you ground them to the negative terminal on your battery? thats what i did works great
Posted: March 22nd, 2004, 4:31 pm
by torpedan
Well this is the best advice i can give
http://www.projectmazda.com/tech/howto/groundwire/
Posted: March 23rd, 2004, 7:18 am
by Freq2002
First off, before applying these nifty kits, it helps if you know what they do,...
The only wires on your throttle body are coming off the TPS which is a self contained insulated unit. Grounding it is useless, and messing with the wiring is a baaaaad idea. Tweaks the CPU & can mess up your eninge something fierce.
The tranny doesn't have a pos/neg. Like the TPS, the wires that DO go in/out of it should not be messed with unless you like walking. Now stock, it should have a bonding strap somewhere in the rear of the engine compartment just to provide a more solid ground from the eng./trans/ to the body. If I recall correctly ist on one of the motor/trans mounts. Replacing that bonding strap with a heavier cable will provide a better ground.
A good way to do this without crawling around under the car is to runa split cable off the neg side of the battery to a good grounding point on the chassis.
Posted: April 21st, 2004, 9:39 am
by LooseChangeRacing
How many wires basicly run from the neg terminal now? I just got a kit from ebay and I was wondering. Can't you just replace all the wires that already run, or is the point to add more wires to more grounding points...
Posted: April 21st, 2004, 1:30 pm
by The_Great_Tonge
has anyone with a mx done this mod?
also if ur inressted pick one up on ebay
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2474782379&category=33574&sspagename=WDVW
you can say you got mazdaspeed ground wires!!
<small>[ April 21, 2004, 12:35 PM: Message edited by: The_Great_Tonge ]</small>
Posted: April 21st, 2004, 6:29 pm
by Gro Harlem
I'm not 100% positive, but i'm pretty sure those "mazdaspeed ground wires" are a complete scam. All the dood did is take background images of MS cars and put some generic car stereo wires with a couple of mazdaspeed stickers on the collector. waste of money, esp for the ridiculous shipping they want for a few wires.
You can get your own "mazdaspeed groundwire kit" for $24.99 at walmart's stereo section :)
Mine works good in my MX3
Posted: April 21st, 2004, 6:56 pm
by The_Great_Tonge
lol yea he is charging like 18 bucks for shipping, whata ****ing ***o
Posted: May 11th, 2004, 6:11 pm
by Ehpl
A cheap source of super heavy duty ground wire I used on my car:
Went to walmart got a cheap set of jumper-cables $7.00 ,sometimes you will find diferent colors if thats important to you?, these cables suck as jumpers but are 10x heaver guaged than you need,but hey more is better, I cut the clamps off ,cut the lengths I needed, then soldered (use electronic soldier) copper eye loops on the ends. :welder:
Eugene L
1.6DOHC
N.S.canada
http://www.cardomain.com/memberpage/552384
