I am doing the BP-T swap. I am using the GTX wiring harness and ecu. Will a MAF from a 86' RX-7 work or does it have to be from the 87-88' RX-7?
Thanks, Travis
MAF
mclaw-mclaren
MAF
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
mclaw-mclaren
mclaw-mclaren
Re: MAF
i did, but i don't know much about RX-7's so is a 86 a sencond generation?
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Re: MAF
Dont the 2nd gen rx-7's use VAF's?
mclaw-mclaren
Re: MAF
if i have a 96 MX
for the bpt swap i am planning on using the ECU and Wiring Harness out of the GTX, want Haltech but to much money.
what VAF would i use with this setup?
Thanks,
Thanks,
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Re: MAF
Just to warn you, the GTX harness isnt exactly the easiest thing to hook up. In facts its not easy at all. But if you are willing to put in the tie for it, it will be good. And I people told me that the 2nd gen rx-7 VAF would work.Originally posted by mclaw-precidian:
if i have a 96 MX
for the bpt swap i am planning on using the ECU and Wiring Harness out of the GTX, want Haltech but to much money.![]()
Thanks,
Re: MAF
the second gen rx7 covered all models from 86-91, but if you look here, it says that the MAF comes from the TURBO rx7s....the year 86 only featured the naturally aspirated rx7s, the TII's didnt come until the following year.
the n/a MAF might work, but i would go ahead and pick up one from the 13BT engine. it would undoubtedly flow better anyway
