miata 1.6Lcams? will they fit?
Posted: September 4th, 2003, 2:06 pm
by NateDog
hey, i was wondering if the 1.6L cams from a miata will fit into our DOHC engins? plus the flywheel? and other engine internals? please let me know. thanx
Re: miata 1.6Lcams? will they fit?
Posted: September 18th, 2003, 9:40 am
by khrys771
your wrong. the engines are the same. the miata 1.6l block is a 323 GTX block, and the head is a GTX head. the differences are the intake manifold, exhaust manifold, and coil packs.<p>the major difference with the intake is that it just points the opposite direction, then in a FWD car. it points towards the belts and pulleys, instead of at the back of the block. and the only reason for the coil packs is cause the dist would hit the firewall in a miata, so thats it. <p>you do NOT put the cams in opposite. you know that the miata is referred to as having a NA6CE well its just a N/A gtx engine. ok
Posted: September 18th, 2003, 11:50 am
by maldo
Wow, I am sorry but you are wrong.<p>The B6ZE and BP found in the Miata uses a distributorless system that has a cam angle sensor located at the intake cam. The B6T (323GTX) head uses an intake cam driven vaccum advance distributor. The MX-3 head (dohc) uses an exhaust cam driven distributor.<p>Miata head
MX-3 head<p>In order to use any of the Miata cams on a MX-3, the intake and exhaust cams must be reversed as the cam that is slotted for the sensor must be matched up to the distributor or cam angle sensor. A general difference between the MX-3 and the Miata is a transverse mounted engine versus longitudenal mounted.<p>NA6CE has nothing to do with it being N/A. That is the chassis code, not the engine code. NA is the cylinder head type, pre'99 Miatae used a NA head designe while the newer '99+ versions use the NB head.
Posted: September 18th, 2003, 3:50 pm
by cjthor
You're right Maldo.
Posted: September 18th, 2003, 4:30 pm
by maldo
Was there ever any doubt? :shrug:
Posted: September 18th, 2003, 10:29 pm
by The_Great_Tonge
cam shaft or cam gear?
Posted: September 19th, 2003, 12:09 am
by maldo
Camshaft. Cam gears are not specific unless using NB cylinder heads on a BP block.
Posted: September 20th, 2003, 6:17 pm
by khrys771
i'm sorry i own a 323, i am different
Posted: September 23rd, 2003, 11:46 pm
by Josh
it definatly works i did it several monthe back. the only major problem was that becaus now the intake cam is from the exaust on the miata and visversa the alignment is screwed up. so you cant use your stock alignment marks. but once done they came out to be very benifical.
Posted: September 24th, 2003, 2:16 am
by Freq2002
I did research on getting the most pull out of the B6 w/o going the easy route of turbo &/or giggle gas, the best info I got was by going over to the Miata forum & asking them detailed questions about what I was looking for. They can direct you to what you'll need, where to get it & how to make it work.
If I ever get my hands on DOHC engine at the local yards (only finding the POS SOHC's) I'm gonna drop all the recommended mods in it. See how far I cam push one of these pigs before they fly apart at the seams.
