rear defroster "PLEASE HELP!"
mazda_stud
my rear defroster is not workin in my car. the fuse is fine. When i push the switch I hear the relay click turn off and on. The led on the switch does not work. Changed bulb still does not work. The lead on the hatch are attached what do I do now. Where is the ground for the rear defroster? Your help would be sweat thanks.
LIFE IS A HIGHWAY I WANT TO DRIVE IT ALL NIGHT LONG!
Re: rear defroster "PLEASE HELP!"
I have the exact same problem.. it started just as winter was finishing so I didn't really miss it that much, but seeing how the summer is starting to come to an end I'm going to start looking into it again. I checked all the same stuff that you mentioned and had the same results.. a few of my friends thought that maybe the button was borked, I was going to post on here sometime soon to see if someone else had a fix, and if not I was going to venture into my local mazda dealer to see what they had to say. If you find out anything I'd really like to know..
