BP engine swap
Posted: May 27th, 2003, 11:23 pm
by RobB6T
Re: BP engine swap
Posted: May 27th, 2003, 11:30 pm
by Marlon
good job man
welcome to the BP powered club
Re: BP engine swap
Posted: May 27th, 2003, 11:35 pm
by natural born honda killer
its been done many times before but congrats on the swap....
Re: BP engine swap
Posted: May 28th, 2003, 9:32 am
by RobB6T
Given how easy it was I could only assume it has been, but all the posts I read on what you need, you always see need tranny from a proto lx, need ecu... I'm not as impressed by this engine though. I had a turbo 1.6L dohc but first I melted a piston, then the oil pump went out- new crank needed, replaced that and it spun a bearing. I just wanted the car to run, the BP was just sitting in my garage...
Re: BP engine swap
Posted: May 28th, 2003, 9:46 am
by Manach
Which harness did you use?
<p>Well, I'm doing the same thing you did..<p>Building myself a B6-ZET, and made a deposit on a Protege GT 90 engine..
Re: BP engine swap
Posted: May 29th, 2003, 3:04 am
by torpedan
they say to go with the protege tranny be naemly because the b6 tranny doesnt last to long unnder abuse.. and the proteges is a bit more stout... other than though though it can be done.
Re: BP engine swap
Posted: May 31st, 2003, 12:00 am
by atila
Adam here in Quebec use the 1.6l transmission in his 323gtx pre89 and his running 356whp on that little tranny. For information about his car go on montrealracing forum and look for turbo323 or 323turbo his the one i'm talking about.
Re: BP engine swap
Posted: May 31st, 2003, 12:11 am
by atila
Adam here in Quebec use the 1.6l transmission in his 323gtx pre89 and his running 356whp on that little tranny. For information about his car go on montrealracing forum and look for turbo323 or 323turbo his the one i'm talking about.<p>How your car running i did the same swap in a friend rs 94 about 2 months ago and i still have some little tuning trouble with the engine. Sometime the car doesn't pull even
