1.6L SOHC idle problems??? anyone?
Posted: January 8th, 2003, 11:43 pm
by shogokuma
when i puch the breaks my engins idles ruff but someone told me to change my ground wire? in a way it dosent sound dumb because lights are from the batery and if i have a bad ground? hummm did someone try this before?
Re: 1.6L SOHC idle problems??? anyone?
Posted: January 9th, 2003, 11:29 am
by azmtbkr81
Check to see if all your vaccuum lines are still hooked up, one of mine worked itself loose one time and caused a weird idle. Just look at the vaccuum line routing diagram on the underside of the hood.
Posted: January 9th, 2003, 12:09 pm
by shogokuma
hey thanks buddy ill try that!
Posted: January 9th, 2003, 12:49 pm
by tk1138
It's probably the same idle problem that most l4's have, just not as pronounced. Improving your charging system is probably the solution. Search for idle in this forum & you'll see a ton of info.
Of course checking for vacume leaks is a good Idea as well.
Posted: January 11th, 2003, 1:26 am
by Paragon
where can i find the vacuum system diagram if it's no longer on my hood?
