Wich wires?
Posted: September 19th, 2002, 9:26 pm
by patapouf
Ok, I've done some searching to find out wich plug wires I should get. Till now im inclined on getting Nology wires. What do you guys think?<P><BR>Hey Maldo, instead of gettin the NGK plugs you sugg. I went for the Beru plugs, should I have considered otherwise?<P>Thanks!
Re: Wich wires?
Posted: September 19th, 2002, 9:27 pm
by quinn_seipp
nologys are wick :o
Re: Wich wires?
Posted: September 19th, 2002, 9:59 pm
by patapouf
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by quinn_seipp:<BR><STRONG>nologys are wick :)
Re: Wich wires?
Posted: September 21st, 2002, 2:59 am
by Freq2002
Magnecor makes some nice stuff, Jacobs Electronics are also pretty nice.<BR>I'd go for something with a good track record & has a no-s--- lifetime warranty.
Re: Wich wires?
Posted: September 21st, 2002, 6:57 pm
by patapouf
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Freq2002:<BR><STRONG>Magnecor makes some nice stuff, Jacobs Electronics are also pretty nice.<BR>I'd go for something with a good track record & has a no-s--- lifetime warranty.</STRONG><HR></BLOCKQUOTE><P><BR>So you dont agree with nology wires? Or are you just suggesting alternatives?
Re: Wich wires?
Posted: September 21st, 2002, 7:01 pm
by OsoSlo z28
all the big names are good, but if you don't have an upgraded ign. setup, you're just paying for the name and looks.
Re: Wich wires?
Posted: September 22nd, 2002, 7:16 am
by Freq2002
Cre8tive is correct, w/o upgrading your ignition system, you're better off getting a good set of Bosch 7mm wires. (Not sure if they make em for the MX3 engine tho,...)<P>As for Nology wires, here's a bit I found on thier website.<BR>"Many racers are skeptical when you tell them they can get horsepower increases from something as mundane as plug wires and a coil. But the Nology HotWires and ProFire do exactly that."<BR>I see a claim like that on a manufaturers website & I go elsewhere. Any good engine builder will tell you that the horsepower of an engine is a set amount depending on it's configuration. A properly tuned HEI ignition such as what comes in the MX-3 will yeild a good burn. Poorly tuned you get a bad burn & loose performance & mild power drops. If your car is in a good state of tune & you get these wires, it's doubtfull you'd get any gains that you could get from putting in a set of cheesey low impedance wires from Accel. All your doing is making a hotter spark, & before y'all start flamin away, no, thats not always a good thing.<BR>The whole capacitor in the wire thing sounds like a cheap way to imitate MSD. Cheap for them, not for you when you pay for it. Especialy if the drain is too much for your coil & it takes a big hairy dump.<BR>My personal take, if you're gonna do it, do it right. Dont get just wires, get the system. Me, I'd get an MSD crank triggered system with programable ignition curve. Beats a dizzy system hands down every time.<P>But then, thats just my opinion,...<p>[ September 22, 2002: Message edited by: Freq2002 ]
Re: Wich wires?
Posted: September 22nd, 2002, 10:56 am
by patapouf
Freq, and Crev<P>Thanks for the advice! As for the MSD product you suggested to me Freq, I cant find it. How much does it run for?<P>You see I have a problem with my engine. When I get to 2000rpm it engine seems to skip a little. I dont feel any loss in power, but its damn annoying! Iwas suggested the renew my whole ign. system(plugs, wires, dist. cap and rotor).
Re: Wich wires?
Posted: September 24th, 2002, 11:24 pm
by Freq2002
The crank tigger system would prolly have to be modified from a system made for another type of engine. All depends on similarities in the parts, but a 4-cyl ingn. sys. should work on any 4-cyl.<BR>Contact MSD with your questions, I have found that thier tech. department is outstanding & can find you the answers you need.
Re: Wich wires?
Posted: September 25th, 2002, 5:37 pm
by patapouf
Ok thanks alot!
Re: Wich wires?
Posted: September 25th, 2002, 8:12 pm
by maldo
The crank trigger system is going to be quite difficult to get to work as the ecu is what controls timing. If you were able to use a miata ecu, it could be done. You may as well go Haltek or TEC-II or III which both use this system and may be cheaper in the long run.<P>I used Beru plugs for years in NA form but switched to the NGK. Personally I fing the NGK better but that is personal preference and based on my current setup. Beru is still a very good brand.
Re: Wich wires?
Posted: September 26th, 2002, 8:27 pm
by patapouf
I also decided to go for NGK's. It helped my problem a little but the car still shakes a little upwards of 2000rpm. Its really pissing me off! Im bringing it the the garage tomorow so hopefully they'll find whats wrong with it! Canadian Tire couldn't! :mad:
