TIMING ADVANCE KIT
Posted: August 2nd, 2002, 12:14 am
by Brandy92 MX-3
does anyone know anything about the timing advance kits,they r selling on ebay,i know its just a resistor,but does it work,and how do u hook it up
Re: TIMING ADVANCE KIT
Posted: August 2nd, 2002, 12:17 am
by OsoSlo z28
don't waste your money
Posted: August 7th, 2002, 4:03 pm
by TedLeeper
If you want your timeing advanced take the car into a mechanic, he'll have a timing light to use on your fly wheel. he could advance or retard the timing. I had my mechanic set mine to 92 octane which you can only get at amaco but it's defenatly worth the preformance boost and better gas milage.
Posted: August 7th, 2002, 4:36 pm
by Sonicxtacy02
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Ted:<BR><STRONG>If you want your timeing advanced take the car into a mechanic, he'll have a timing light to use on your fly wheel. he could advance or retard the timing. I had my mechanic set mine to 92 octane which you can only get at amaco but it's defenatly worth the preformance boost and better gas milage.</STRONG><HR></BLOCKQUOTE><P>Ted how much was it advanced? How did he trick the ECU into not adjusting?<P>If you want my opinion, its the same as ashley's.. dont waste your money<BR>
Posted: August 7th, 2002, 5:00 pm
by 92RedMX3
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Ted:<BR><STRONG>If you want your timeing advanced take the car into a mechanic, he'll have a timing light to use on your fly wheel. he could advance or retard the timing. I had my mechanic set mine to 92 octane which you can only get at amaco but it's defenatly worth the preformance boost and better gas milage.</STRONG><HR></BLOCKQUOTE><P>The computer should auto correct the timing to move it back to the correct level. The other thing is you set it to a certian degree BTDC(before top dead center. There isn't a way to set it to a octance. Just adding ny 2 pennies
