Distirbutor O-ring help #2
Posted: May 30th, 2002, 3:57 pm
by wainaink
Thanks for the help guys. Just one more question before i attempt to change it. The mark on the distributor, how do i do it!! Do I use a pen and mark across, then align the distributor with the mark i made when am putting it back together??? messing up the timing is something i don't want. On a budget here.
Re: Distirbutor O-ring help #2
Posted: May 30th, 2002, 8:35 pm
by white94mx3
Use a Peice of chalk (yellow or white) and mark a part of the distributer that will not change form in away way, and a part on the head that won't change form in any away, and make sure that they are lined up evenly, so that when you put it back on, you can line it back up, then tighten the bolts
Posted: May 30th, 2002, 8:36 pm
by white94mx3
Oh yeah! and Be sure to mark the timing BEFORE you Change anything! or else you could mess it up!! Don't even put a ratchet close to a bolt before you have marked it!
Posted: May 31st, 2002, 3:45 pm
by wainaink
Thanks guys, i'll be doing it this weekend.
Posted: June 4th, 2002, 12:49 pm
by wainaink
Hey guys i just finished changing my O-ring it wasn't that bad at all. Took me less than 1 hr and i ended up changing my distributor rotor and cap while i was in there. Hope it takes cared of my leak problem. Thanks again guys!!!!!!!!!!!
Posted: June 4th, 2002, 3:06 pm
by wainaink
Just! one more thing for anybody who might hsve the same problem. For the 93 mx3 1.6 4cylds, the Distributor O-ring size is; Width 1/8" , Inner Diameter 1-1/2" ,outer diameter is 1-3/4". I only paid $1.50 saving me the $50 mechanic was trying to rip me off. Thanks again.
