more bad news
babygirl23
more bad news
I just had the alternator fixed today, changed both the alt. belt and the ac belt because i had squeeky belts it cost me $300 for the whole job which i think is expensive and know today i drive it and the check engine light comes on which has never happened to me before and the car starts shaking and it wants to stall when i stop. I don't know what the hell is wrong, hopefully somebody can help me figure out this problem<P>jamie <BR>95 mx-3
renef
Re: more bad news
You may want to open up the hood and see if everything is connected. Maybe they left something out. Sounds like a loose tube or hose to me.<P>Check: (all this is in easy reach)<P>PCV valve is inserted all the way in<P>The MAF meter cable and connector is plugged<P>All of the black plastic hoses should be tight.<P>The air intake hose (the biggest one in there) should be tight<P>sensors, plugs, grounds, any loose stuf that looks like it should be plugged in somewhere.<P>RF
White 1992 MX-3 RS Turbo<BR>"Live Boosted or Die!"
