Tune Up Cost???
Guest
Re: Tune Up Cost???
You will probably have the Spark plug replaced at $6, the Spark Plug Wires, $55 with NGK Brand, the Distributor rotor is around $5 from Mazda, and then the DIstributor Cap is around $28, Make Sure They give you the Correct One! These are all stuff you can do your self. It should take more than 10 min, and you will need a 10mm wrench or Socket and ratchet. and A spark plug socket and 6in extention and a Spark Plug Guage. The gap on the plugs are .0043, Some companys say .0041-.0045.<P>I guess around $95-100 with you doing that your self. SOme tune-ups also include a new fuel filter and air filter. The fuel Filter at O'rielys is made by wix and $23. And Air Filter , $10 Chris
Re: Tune Up Cost???
If you can do-it-yourself, it's a good idea. I didn't have time so I left it in the shop while I was out of town. It came to $400CDN ($260USD) when it was all said and done.<P>------------------<BR><B><A HREF="http://www.mp3.com/nealpinto" TARGET=_blank>¡¡LISTEN TO MY MUSIC!!</A></B>
