Another clicking noise
Posted: June 23rd, 2001, 7:32 pm
by mx32nv
This clicking noise is coming from the engine, it seems to be internal right under the valve cover. It is louder at idle but sometimes will just stop for no reason and then my car is quiet again. The clicking speeds up as I accelerate. A friend of mine mentioned that I should check into having my valve timing looked at. I have a 1.6L SOHC and 110K miles.<P>Any thoughts on what this could be?<P>Thanks<P>Troy<P>------------------<BR>93 1.6L SOHC Teal
Re: Another clicking noise
Posted: June 24th, 2001, 10:24 pm
by mxcess
I have a '92 1.6L SOHC that makes the clicking noise at start-up and goes away as soon as the engine warms up to normal operating temp. I think it is just something to do with the choke or something. If it is doing it even after motor is warm and after a long trip you might have a problem with your valve train. Like a clogged lifter or something. At your next oil change you might try putting a cleaner in your crankcase before doing the change. I use B12 Chemtool myself to clean the motor. Just make sure you follow the directions on the can and DO NOT drive the car with the cleaner still in the system or you might damage the bearings. I would try that first since it is fairly simple and doesn't cost much. Hope this helps. Just my $.02 worth.
Posted: June 24th, 2001, 10:53 pm
by mx32nv
Is that the same thing as an engine flush? Because I've done that before so that would be something I feel comfortable doing myself. Unfortunatly I just changed my oil about 2 weeks ago but if this is what your talking about I'll give it a try.<P>Thanks<P>Troy<P>------------------<BR>Troy<BR>93 1.6L SOHC Teal
Posted: June 25th, 2001, 12:08 am
by mxcess
Posted: June 25th, 2001, 12:16 am
by mx32nv
Thanks..I'll give that a try.<P>------------------<BR>Troy<BR>93 1.6L RS Teal
