steering column
babygirl23
steering column
Ok, i need to replace my combination switch. I found one for the same year as mine, it only cost me $25US. I got two problems, when we disconnected it a spring fell out that makes the clicking noise for the turn signal, not really to sure how to fix it. The other problem is finding someone to do the job. It seems like it is a pain considering that there is alot hooked up behind the steering column. I'm also worried about messing up the air bags. Any suggestions....
