93 MX-3 V6 hesitation issue(edited 7/15/12)
- cWs306
Re: 93 MX-3 V6 hesitation issue(edited 7/15/12)
Thats little random thing on the top of the disty? my cousin had the same issue but his car wouldnt start at all untill he shook the wire n moved it around a bit.
Jazzylay20
wtf is that the coil?cWs306 wrote:Thats little random thing on the top of the disty?
- cWs306
noo. its apart of the coil im pretty sure tho. the 3 prong plug on the back side of the 6 prong plug is the coil. multi-meter and test the 2 outter prongs on the 3 prong plug. should be 11.5-18ohms.
kyser182
Re: 93 MX-3 V6 hesitation issue(edited 2/4/13)
So just as an update to this if anyone cares =P
So O2 Sensor solved most of the problems I was having.
Cleaned MAF and TB
Went though and checked all Vacuum hoses
Changed Spark plugs and wires
Checked Disti
Checked timing
Replaced fuel filter
The last thing i did.. and i did it sunday before the superbowl
Was check and adjust the TPS
That probably made the single largest difference out of everything. Altho im sure everything i did prior didnt hurt!
It is like driving a completely different car. I can press on the gas pedal no matter the RPM / gear
and it just GOES!
yay for all the MX-3 guys/gals!!!!
Cleaned MAF and TB
Checked Disti
Checked timing
and it just GOES!
1993 MX-3 GS
